08-20-2014 07:35 AM
Hello Vincent,
Does the Shipping Example mentioned the post above list the codec?
Can you share the VI you are using?
Can you share an NI MAX Report?
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
Thanks for your cooperation!
10-13-2014 06:29 AM
Hello Thierry,
Sorry. I worked on others projects. Here's my MAX Report.
Kind Regards,
Vincent
10-14-2014 02:52 AM
Hello Vincent,
Can you also provide answers to the following two questions?
1) Does the Shipping Example mentioned the post above list the codec?
2) Can you share the VI you are using?
05-17-2021 04:22 AM
Hi, the reason is that you have a grayscale image and Xvid is for color images.
"IMAQ AVI2 Get Codec Names" will only show you compatible AVI compression codecs...
Use "RGB (U32)" in "IMAQ Create" and load with "IMAQ ReadFile 2" a color image. Now "IMAQ AVI2 Get Codec Names" will also show "Xvid MPEG-4 Codec".
You can store a grayscale image with Xvid MPEG-4 Codec, but I think LabVIEW will convert it to RGB first. This needs extra time. Consider a pipelined structure with "IMAQ Cast Image 2" vi.
Greetings
Andreas
