Without NI DAQ device- how to get data from MSP into labVIEW and process it
I do not have an NI DAQ device. I have an MSP430 and my sensor is an ADXL335 Accelerometer. How do I get data from my MSP into labVIEW and process it?
Just looking for a nudge in the right direction. I'm having a hard time finding resources on labVIEW that don't involve NI specific DAQs.
Thanks in advance,
Aziz
(2,773 Views)
Can you package your data as ascii or xml or in a known binary packet?
Can you transfer it to a LabVIEW computer via TCP or Serial communications?
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(2,733 Views)
www.ni.com/idnet
Are there drivers made for your device already so you can talk to it that way?  Otherwise, how do you communicate with the device?
(2,718 Views)
You've hardly provided any information. Do you just have the micro and need to design and build a circuit board for it? You would then need to decide on the physical connection to a pc. Is it an evaluation kit with an existing connection? If so, what type? Other than this processing that you want to do, most of your programming is going to be with c and the ide that comes for the micro. This board is not the correct place to ask questions related to that.
(2,695 Views)
There are many ways to get data into LabVIEW that do not involve NI-DAQ devices.
I think your easiest option would be to stream it via serial port if the data rate isn't too fast.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(2,665 Views)
