Hi Michael,
which DAQmxBase driver are you using? I attached a link to the DAQmxBase driver 1.5. This is the latest driver which supports LV PDA 7.1
http://forums.ni.com/ni/board/message?board.id=170&message.id=211286
Can You test the PCMCIA card in a laptop to verify if the card is working properly. You set the card to bipolar. Which input range did you set?
Mayby it is set to a negative range.
Klaus Dinnes
