12-03-2014 05:36 PM
Used to be semi-transparent, now becomes totally transparent. Anyone see this:
12-03-2014 05:56 PM - edited 12-03-2014 05:57 PM
I haven't got 2014 to try it but is the wire inside the case structure not connected to the case selector and the error out terminal but you just can't see the vertical wires because they're outside of the bounds of the case structure?
The branch of the error in goes behind to the sequence structure.
I want to see you triple click on some wires to be sure
(If this isn't a trickery of the wires then it's a feature of LV2014 I didn't know about!)
12-03-2014 06:03 PM
No the VI is made for the post.
I wired it right before the post.
Here is another one:
12-03-2014 06:06 PM
LabVIEW Pro. version: 14.0f1 32 bit on Win7 64 bit.
12-03-2014 06:16 PM
I didn't PS the image.
Here is the test VI.
If it's opaque, add this to your .ini file:
structuresFadeToDiagramBeneath=TRUE
12-03-2014 06:17 PM - edited 12-03-2014 06:17 PM
Is your post just an observation you've noticed and you wanted to share?
(Edit: Yes, apparently so!)
12-03-2014 06:19 PM - edited 12-03-2014 06:21 PM
I wonder if there is another secret .ini setting that I don't know of, which can fix the problem ?
12-03-2014 09:49 PM
George,
You may want to create a VI in LV 2013 and the same one in 2014 and show the difference. Also, note that you have a special INI key set to enable this setting of semi transparent. Most users don't know that exists.
12-03-2014 10:47 PM - edited 12-03-2014 10:48 PM
Here is how it looks like in LabVIEW 2013:
12-03-2014 11:41 PM
Why would you be trying to hide wires behind strucures in the first place?
