Will LabVIEW 5.1.1 run on Windows XP?
Will LabVIEW version 5.1.1 run on the Windows XP operating system?
(3,013 Views)
LabView 5.1.1 officially supports up to Windows 2000. So you would rather upgrade to LabView 6.1 and above.
I have installed executables built with version 5.1.1 on an XP system and it worked fine.
Note, some functionality may not work, since protocols may have changed. If you are using activeX, it may not work in some cases. I have read threads about serial communications being not fully compiant; so beware
(2,999 Views)
We have recently installed it on WinXP, don't have a real feel for any possible issues, but the only noticeable issues was a little error message box "Wrong OS", which goes away when clicked. Good luck.
Putnam Monroe
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,997 Views)
perdi los disco de  poliview labview  5.1
(438 Views)
if you are using an executable  built with LabVIEW 5.1.1, then you have to install the LabVIEW runtime engine 5.1.1
http://download.ni.com/#support/labview/windows/runtime/
(429 Views)
