06-09-2017 06:19 AM
You are correct!
I can not open your example because I run an older version (2013). I will highly appreciate it if you could save to an older format.
06-09-2017 06:28 AM
Of course. Hope this works for you.
06-09-2017 06:34 AM
@wentao_ji i don't come from an engineering background, im just a lowly cs (calisthenics studies)
@cookie_monster9 to whom are you referring with "You are correct"?
06-09-2017 06:37 AM
Thank you for the file - this was exactly what I needed. Basically you just build an array and append to it so the data set is suitable for a graph.
