02-10-2011 03:52 PM
You are missing some subVIs in the demo file, but I was able to roll my own and it appears that the scaling is being done with nearest neighbor interpolation. I was able to finely tune the scaling and see quite crazy results (you seem to have hit a relative "sweet spot") other factors are quite worse. My own scaling VI uses bilinear interpolation which gives a much better result with a slight hit in speed. My suggestion is to use the zoom factor of the picture control.
The Front Panel looks like this on my machine:
Checking the zoom three different ways: Get Image Scaled, Home-built interpolation, built-in zoom
02-11-2011 10:45 AM
Hmmm. I don't see which ones - everything in my copy is in the BugDemo folder, or in VI.lib.
Yeah, that does look better. It's just a print-preview, but for critical stuff, the SCALED IMAGE thing is not to be trusted.
Thanks for your insights.
Blog for (mostly LabVIEW) programmers: Tips And Tricks
