Why ist it impossible to set the instrument housing size and bounds programmaticaly?
Dear LV enthusiasts,
I have a slightly old project from LV 6. Since this time I am using the
oppurunity to set and change the housing size and bounds of
indicators at runtime. This is a very nice feature. Using this I am
capable to have a user defined window with moveable and  resizeable
indicators.
Within LV 8 I noticed that this feature is gone. all the properties that
change the size of the control are read only.
I am very disapointed about the loss of functionality in the new versions.
Its a real handcap for the development of new software versions.
Is it possible to have this properties with read / write again?
Yours with kind regards
      Martin
With kind regards
Martin Kunze
KDI Digital Instrumentation.com
e-mail: martin.kunze@digital-instrumentation.com
Tel: +49 (0)441 9490852
Message 1 of 9
(2,747 Views)
Just tried this in LV8.2 with a string control and indicator. No problem it still works
Message 2 of 9
(2,726 Views)
I want to use a gauge.
Sorry
With kind regards
Martin Kunze
Message 3 of 9
(2,722 Views)
Working on LabVIEW 8.0
And here is the set of property nodes for varying the front panel object size of a Numeric, Boolean and a string control
they have both read and write option.
can you please illustrate this with an example code??
Message Edited by devchander on 12-20-2006 05:57 AM
Message 4 of 9
(2,723 Views)
The housing size property for gauge is settable in LabVIEW 8.0
Look at attached pic for corresponding property node
are you missing something?
Dev
Message 5 of 9
(2,719 Views)
Also with a Gauge no problem to change the housing size.
Message 6 of 9
(2,717 Views)
Try to use the bounds insted of the housing size.
With kind regards
Martin Kunze
Message 7 of 9
(2,708 Views)
There you are right. Back to square one
Message 8 of 9
(2,694 Views)
As far as I can remember, the Bounds property has always been read-only (hence notes in the KnowledgeBase like Bounds Property of Front Panel Objects is Read-Only.)
 Could you have been using something else in your old project?
Fading out. " ... J. Arthur Rank on gong."
Message 9 of 9
(2,634 Views)
