04-28-2015 04:29 AM
Hi
Why bellow block diagram isn't work? and Boolean never is True?
Thanks.
04-28-2015 04:51 AM
The events from controls (and indicators) are triggered by user interactions. As you update the indicator with a local variable, no user interaction takes place. There is however a way to simulate a user interaction, you can use a property node of the indicator and set the 'Value (signaling)' property.
04-28-2015 11:00 PM
Thanks a lot. My problem has been solved
