03-31-2015 05:14 PM - edited 03-31-2015 05:15 PM
This is sort of a follow-up to that message where I described what I think is a bug which does not allow using the "IndexVals" property of a Strict Typed Def array in "Write" mode (at least without jumping through a few hoops).
In short, if I take a reference to a Strict Typed Def array and use the "IndexVals" Property in "Write" mode in a SubVI (which I can access without gimmick, interestingly), this throws an error 1082, with the following Explanation:
LabVIEW: Operation not valid for strict type definition instance. Property Name: Index Values
I have searched for both the error code and the error message and found these threads:
http://forums.ni.com/t5/LabVIEW/error-1082-with-active-cursor/m-p/146497
http://forums.ni.com/t5/LabVIEW/Why-does-a-strictly-Typed-Control-cause-error-1082/m-p/125418
It seems to have been diagnosed as a bug (but without a CAR) at least since 2004, but apparently this is still an issue in LV 2013 SP1 (which I tested it in).
Nothing about Strict Typed Def throwing an error with this property in the Help.
Time to kudo this idea... and fix this bug!
04-01-2015 04:16 PM
Hi X,
I think Paul may have answered this question in the message this post is referencing. Part of the functionality of a strict type def is restricting what you can change.
http://forums.ni.com/t5/LabVIEW/Array-Index-Values-Property-Read-Only/m-p/3112536#M892653
04-01-2015 06:29 PM - edited 04-01-2015 06:37 PM
I think Hoovahh in that thread has objected to that answer better than I could have.
Now, it is perfectly fine for NI to stand their ground but it doesn't make any of the things I have reported consistant for that reason.
04-02-2015 11:48 AM
Hi X,
So we dug a little deeper into this and couldn't find a CAR filed for this specific issue. A new CAR was created (#512512) and R&D will investigate this further.
You can monitor the list of known issues and bug fixes at links such as these:
http://www.ni.com/product-documentation/52150/en/
http://www.ni.com/product-documentation/52151/en/
Thanks for bringing this to our attention!
