11-17-2015 03:13 PM
I have a labview program to command the motorized stage to rotate and measure light output using Konica Minolta CS-100A photometer.
Photometer is connected to PC through RS-232.
Program works fine yet, the data is zero at decussate format (please see below table), the error out shows status ok all the time, for row with zero data the error code is nothing, and for rows with the data there is an error code "107367629"
I also attach the program and some pictures, could someone help?
Angle | Intensity | x | y | error code | |
0 | 340.1 | 0.443 | 0.405 | 107367629 | |
10 | 0 | 0 | 0 | 0 | |
20 | 345.99 | 0.443 | 0.405 | 107367629 | |
30 | 0 | 0 | 0 | 0 | |
40 | 343.33 | 0.443 | 0.406 | 107367629 | |
50 | 0 | 0 | 0 | 0 | |
60 | 335.73 | 0.443 | 0.406 | 107367629 | |
70 | 0 | 0 | 0 | 0 | |
80 | 323 | 0.443 | 0.406 | 107367629 | |
90 | 0 | 0 | 0 | 0 |
Solved! Go to Solution.
11-17-2015 05:27 PM
How does the value of the "read buffer" look like when zeroes are returned?
(Your code seems problematic with race coditions and serious overuse of local varaibles but that's probably not the problem here).
11-18-2015 09:56 AM - edited 11-18-2015 09:57 AM
"107367629" is a VISA Timeout error
"0" is the default value for the Fract/Exp String To Number Function
So when your write-meas-read VI times out or receives invalid data it returns the value of 0
11-18-2015 11:16 AM
Thank you RTSLVU,
How can I modify the program to get a continuos data?
11-18-2015 11:18 AM
Hello Altenbach,
It is the same....
11-18-2015 03:22 PM
Hello everyone,
Could someone suggest a solution for this problem?
Thank you so much
11-18-2015 03:57 PM
11-19-2015 11:15 AM - edited 11-19-2015 11:15 AM
@YBU wrote:
Hello everyone,
Thank you so much
Sorry man, you know most of us here have jobs and help people on this forum in our spare time expecting nothing in return.
The first question is how is the serial data formatted? Does it have a termination character? That is to say does the data sent from the device always end with a carriage return or new line character? Most serial device do this.
11-24-2015 04:16 PM
Dear RTSLVU,
Thank you for paying attention to my problem, and thanks so much for clearly solved my problem,
You were right.
Thanks for helping people like me 🙂
