07-25-2005 11:01 AM
07-25-2005 01:20 PM
07-25-2005 01:43 PM
07-26-2005 02:48 PM
Hello Dan,
It is a known issue that some functions take longer in RT than in Windows. R&D is looking into this issue and will make a fix in a future version of NI-DAQ. In the meantime, it is much faster to programmatically create tasks in LabVIEW than it is to use tasks or virtual channels created in MAX.
07-27-2005 02:14 PM
07-28-2005 07:21 AM
I believe that Sean C. was referring to creating tasks at run-time using the DAQmx Create Virtual Channel VI and then using the outputs with the read and write DAQmx VIs, rather than setting up my channels in NI-MAX and using their names as the inputs to the read and write DAQmx VIs. It apparently takes less load time for the former than the latter.
08-08-2005 05:17 AM
