01-15-2013 01:31 PM - edited 01-15-2013 01:33 PM
01-15-2013 01:46 PM
sure, I'll post some code tonight. Thanks!
01-15-2013 02:41 PM
rothloup wrote:I'll let you know that exact CPU model when I get back to the computer later tonight, but it's an 8-core Intel.
Thanks. I wonder if it is 8 real cores or 8 virtual cores (i.e. 4 hyperthreaded cores).
I have a Dual Xeon E5-2687W (16 cores total, 32 when counting hyperthreading) and have no problems keeping all cores busy using LabVIEW.
01-15-2013 08:18 PM
ok, here is my CPU info:
Intel(R) Core (TM)
i7-2630QM CPU @ 2.00 GHz
Some more info:
Windows XP Pro, Service Pack 3
Labview 2012
01-15-2013 08:35 PM
ok, here are some code snippets.
The first one is the main loop. I've cut out the larger loop, which would just clutter things up. This is where all the computation takes place.
The first two VIs, where one is stacked on top of the other, run in parrallel. They simulate the various objects (one reader, lots of ID Tags) that exist in the simulation. The next two VIs (inside the diagram disable structure) essentially just loop over all of the objects and either read or write a single value to each object. That code is shown in the 3rd and 4th snippets. (4th snippet in next post - I guess I'm limited to three attachments).
The "Calc Num Threads.vi" is just a wrapper around the "CPU Information" vi that tells me how many logical processors are available. It returns 8 on this system.
Thanks for any help. Let me know if I should post any more code or information.
01-15-2013 08:39 PM - edited 01-15-2013 08:52 PM
4th snippet.
The read/write VIs in this snippet and in the previous posting titled "Response to ID Tags" are the basic data-accessor VIs that LV automatically creates in an object-oriented program.
I've also included a snapshot of my task manager while the program is running. Nothing else is running at the same time.
01-15-2013 11:59 PM
01-16-2013 05:37 AM
Isn't the default in a parallell loop max 4 threads? That'd explain the 50%. Try changing some loop properties to 8 and see if there's any difference.
/Y
01-16-2013 08:03 AM
Yes, if I recall the default was 4, but I changed them all to be 8. and I wire the number of logical processors to the "P" input, which in my code, is returned as a value of "8" by the Labview "CPUINFO" function.
I re-checked all the loops to confirm that none of them are set to less than 8.
but I wonder if there is another, more well-hidden setting somewhere which is limiting the number of parrallel loops?
Thanks for the suggestion.
01-16-2013 08:17 AM
ok, you're right, good catch! I was just counting the number of graphs in the task manager.
I guess it's one graph per logical processor, right? So i've got 4 cores but each core is shared across two CPUs?
If so, then it seems that the problem might be related to how well the OS and/or Labview is hyper-threading the work.
any clue as to how I can troubleshoot or improve that? Or is that not the right path to explore?
Thanks!
