05-27-2014 09:35 AM
Hey guys,
I recently noticed that my FPGA compilation stops! (Or it doesnt progress, to be accurate)
Theres no error or anything. The progress bar will get stuck at a status, and no matter how many hours is put in, it will not move.
It doesn't always get stuck; currently the chance is about 70%.
It might get stuck at device utilization or timing, so it is always not at the same process
I tried rebooting computer, creating a new project with an empty FPGA VI and it still will not complete.
Does anybody know how to fix/investigate this issue?
05-28-2014 02:07 PM
Hi doradorachan,
Can you tell us what OS, what versions of the compilation tools, LabVIEW, FPGA Module, and NI-RIO are you using? These would be helpful to determine if there are any incompatibility issues. Also, how long is the longest time that it has spent compiling?
David Bell
05-30-2014 02:55 AM
Windows 8.1
LabVIEW 2013 SP1
FPGA module 2013 SP1
I forgot which NI-RIO but it is the one that comes with Developer Suite 2014 DS1
I was told by another AE that xilinx compilation tools 14.4 is not compatible with windows 8.1.
Another windows 8.1 laptop with the same LabVIEW versions can compile them fine
so I am not sure if it is actually a compatibility issue. But I guess I will just have it compile them for the time being
05-30-2014 09:33 AM
Unfortunately, it is likely an issue with the operating system. NI Compile Tools repackage the Xilinx Compile Tools and currently Xilinx does not support compilation on Windows 8. Something about how system structure is different. Is the windows version the same on both computers? There are normally different flavors of Windows (Professional/Student/Enterprise) that could play a factor. Or really just a lucky compile that gets around the whole not sure where to read on the new OS type of deal.
09-15-2014 05:58 AM
I have tried this
making all the right modifications on the .bat file for the correct paths and it worked for me.
LabVIEW 2014 DS2
(inc. LabVIEW FPGA 2014 Module)
Windows 8.1
including the modified .bat file for default folder installation and the correct SmartHeap DLLs from the Xilinx Forum link above.
Hope this helps 😉
11-05-2014 08:21 AM
Xilinx_Win8_fix_for NI_FPGA.bat
set RUNPATH=%~DP0 set XILPATH=D:\NIFPGA\programs set SH32PATH=%RUNPATH%SmartHeap-Windows8\SHSMP.DLL set SH64PATH=%RUNPATH%SmartHeap-Windows8\SHSMP64.DLL echo Applying patch... copy %SH32PATH% %XILPATH%\Vivado2013_4\.xinstall\bin\nt copy %SH64PATH% %XILPATH%\Vivado2013_4\.xinstall\bin\nt64 copy %SH32PATH% %XILPATH%\Vivado2013_4\ids_lite\ISE\lib\nt copy %SH64PATH% %XILPATH%\Vivado2013_4\ids_lite\ISE\lib\nt64 copy %SH32PATH% %XILPATH%\Vivado2013_4\lib\win32.o copy %SH64PATH% %XILPATH%\Vivado2013_4\lib\win64.o copy %SH32PATH% %XILPATH%\Xilinx14_7\.xinstall\bin\nt copy %SH64PATH% %XILPATH%\Xilinx14_7\.xinstall\bin\nt64 copy %SH32PATH% %XILPATH%\Xilinx14_7\common\lib\nt copy %SH64PATH% %XILPATH%\Xilinx14_7\common\lib\nt64 copy %SH32PATH% %XILPATH%\Xilinx14_7\ISE\lib\nt copy %SH64PATH% %XILPATH%\Xilinx14_7\ISE\lib\nt64 copy %SH32PATH% %XILPATH%\Xilinx14_7\PlanAhead\lib\win32.o copy %SH64PATH% %XILPATH%\Xilinx14_7\PlanAhead\lib\win64.o copy %SH32PATH% %XILPATH%\Xilinx14_4\.xinstall\bin\nt copy %SH64PATH% %XILPATH%\Xilinx14_4\.xinstall\bin\nt64 copy %SH32PATH% %XILPATH%\Xilinx14_4\common\lib\nt copy %SH64PATH% %XILPATH%\Xilinx14_4\common\lib\nt64 copy %SH32PATH% %XILPATH%\Xilinx14_4\ISE\lib\nt copy %SH64PATH% %XILPATH%\Xilinx14_4\ISE\lib\nt64 copy %SH32PATH% %XILPATH%\Xilinx14_4\PlanAhead\lib\win32.o copy %SH64PATH% %XILPATH%\Xilinx14_4\PlanAhead\lib\win64.o echo Done applying patch. pause
02-24-2015 03:42 PM
Hmm, this worked for me on two other Windows 8 boxes with Labview 2013 but not working on new Windows 8 box with Labview 2014 (professional 14.0f1) even with Compiler Worker in Windows 7 Compatibility Mode.
Anyone have other ideas?
Steve
02-25-2015 08:12 AM
2014 does use a different set of Xilinx tools then 2013 :
Which Version of the Xilinx Compile Tools Do I Need to Compile My LabVIEW FPGA Code?
Workaround : You can use FPGA Cloud Compile (free with SSP):
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209927
02-25-2015 08:56 AM
I have the correct Xilinx Tools version (14.7). I'm now downdrading to 2013 to see if that helps.
03-10-2015 09:38 PM
Hi reading these answers, I only changed the CompileWorker.exe and the other .exe in the same folder to run with Windows 7 Compatibility.
I’m using Windows 8.1 Pro, Labview 2013 DS2, Xilinx14_4
Now my FPGA complier is working again!
