06-03-2015 04:56 PM
Specifically the Weather Monitor example under connectivity/Web Services and the FPGA design examples.
There are several parallel loops. One of the parallel loops will be in the top level VI. The others are all in sub-VIs. After the third example I was looking at it seemed obvious this was being done as a standard, but I don't know why it matters.
Why not all of them as SubVIs? Why not all of them as top level loops? (Well OK maybe not that one.)
06-03-2015 05:16 PM
My guess would be to keep the complexity of each block diagram down - encapsulating functionality into SubVIs - in order to make the example more easily understood. But yes, operationally (bar minor call overhead) it would be indentical.
06-03-2015 06:01 PM
06-03-2015 06:26 PM
For me, it depends on what is happening in the parallel loops. When I have modules that just need to run in parallel with the main loop, it helps reusability to have it a a subVI call. I can then just copy that library to another project and use it.
