10-08-2015 03:51 AM - edited 10-08-2015 03:55 AM
Hello Everybody,
I have an DAQ wich measured every second 4 values on 4 Channels... and it actually works well.
After a while (ca. 3/4 h) the program starts to hang on my PC and crashes.
Next, i try to restart my programm - but there comes an error message >>Resetting VI: ... << but the reset start to hang to.
Now I'm totaly clueless why and I would lik eto know, whats wrong. Maybe someone can help me.
P.S.: I also varied the baudrate, parity, bits... but it doesnt helps.
Marc
10-08-2015 03:54 AM - edited 10-08-2015 03:55 AM
Marc,
you shouldn't open and close repeatedly interfaces you require throughout. Open the File and the VISA connection once before the loop and close them after leaving the loop.
Norbert
EDIT: Also note that in the past power saving settings of PC had weird issues with USB and Serial interfaces. Maybe you want to check those.
10-08-2015 03:59 AM
I dont know exactly what you mean.
Couldt you show me what you mean with the aid of the .vi at the attachment?
Cheers,
Marc
10-08-2015 04:03 AM
P.S.: even without the upper part (everything after the READ BUFFER) which i deleted for a test, the programm starts to hang...
so i assume, the problem is in the visa settings
10-08-2015 04:59 AM
10-08-2015 07:51 AM - edited 10-08-2015 07:52 AM
Just to reiterate: You should not repeatedly open and close you serial port. Initialize it once before your loop and close it once after your loop.
10-08-2015 07:53 AM
I tried implement your advice, but after that the programm doesnt work at all.
10-08-2015 08:00 AM
What does your Read Buffer look like? Are you sure you are properly connected to your instrument?
10-08-2015 08:03 AM
What does "doesn't work at all" exactly mean? Does the error in your screenshot occur in iteration '0'?
I assume that you don't fetch all reply characters which creates an buffering issue. That means: With your Open/Close approach, you simply discarded the buffers. That enabled you to make errors by reading too few characters without even noticing.
Another option might be that your VISA write already runs into an error but as the error cluster is not wired, the VISA Read reads nothing and the Scan From String runs into an empty string.
In both situations, you have to improve error handling.
Also dont put outputs left of the loop (VISA Close).
Norbert
10-08-2015 08:12 AM - edited 10-08-2015 08:14 AM
The READ BUFFER is empty and the connection to the instrumen tis fine.
(I tested the connection with an older program version.)
The error massage does pop up after few seconds with the >>scan from string<< symbol blinks.
