06-06-2009 06:40 PM
I am creating an installer for my application but I get the following error when building it.
CDK_Item_OnDoProperties.vi.ProxyCaller >> CDK_Item_OnDoProperties.vi >> CDK_InstallerConfiguration_Editor.vi >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_PreBuild.vi >> CDK_Validate_DistParts.vi >> CDK_DistParts_GetInstalledProducts.vi >> NI_MDF.lvlib:MDFProdInfoList_Open.vi
Also, the Additional Installers List is empty.
I have read many other posts but none has given a definite solution. I already repaired my intallation of LabView 8.5 and it did not solve the problem.
Solved! Go to Solution.
06-07-2009 09:10 AM
jarc15 wrote:Also, the Additional Installers List is empty.
I think this is the key to the problem. I suspect some software you installed after LabVIEW (prior to you trying a repair) screwed up the list. Do you remember what you installed after installing LabVIEW?
A last resort would be to do a complete uninstall of all NI software and then reinstall. A last last resort would be to uninstall, use MSIBlast, and then reinstall. Note: I'm not suggesting to do the above steps, but you might as well know about them should everything else fail.
06-07-2009 01:32 PM
Thank you for the answer. I did not install software after LabView 8.5, but I did install a Trial Version od LabView 8.6, and the Visa4.2 Sotware a couple of weeks BEFORE. Do you think that may be the problem?
Can I uninstall everything without using the software you mentioned?
thanks again.
06-08-2009 09:02 AM
06-08-2009 09:28 PM
OK, this is the solution that worked for me. Thank you for your help.
-Using msiBlast, unistall EVERY NI product. It took me about 3 hours.
-Remove the register trees mentioned in the link above.
- Run a clean up software, in my case Vaio Care.
- Reinitalize
- Reinstall Lab View BEFORE anything else (VISA, anything)
- And there you go!
Apparently, having installed the 8.6 version before did something to the 8.5 version.
