04-21-2015 02:19 AM
Software Version:
LabVIEW 2013 (32bit)
Windows server 2008 r2 (64bit)
OPCenum.exe installed
04-21-2015 08:17 AM
Artyom,
What are you running when you get this error?
04-21-2015 09:19 AM
When i am using NI Distributed System Manager, adding process and then adding opc io server
04-21-2015 06:22 PM
Can you confirm that the OpcEnum service is running by going to Start - Control Panel - Administrative Tools - Services?
04-22-2015 12:25 AM
Andrew T.
Yes, it`s running.
Here is a screenshot services window
04-22-2015 03:00 PM
What does your setup look like? Is the server hosted on the same machine as the process that is throwing the error?
It might be DCOM settings. This webpage gives a rundown of how to configure most of the DCOM settings that should be important.
