06-20-2006 02:53 PM
06-20-2006 04:13 PM
What are you using as the simulated power supply and what type of device will you be using to measure the voltage? Do you want your program to step the voltage source as well? For NI DAQ boards, there are numerous shipping examples (Help>Find Examples) and if you are using a new DAQ board and the DAQmx driver, you can use the DAQ Assistant.
For the animation, I think you would have to use ActiveX to control the flash player. I've not done this but you could try searching the forum to see if anyone has ever posted an example.
