10-05-2011 03:08 PM
We use a SCXI-1102 input module and 1303 terminal block to take thermocouple readings. We want to add a current transducer to the DAQ. It looks like we need to solder a 249 ohm resistor into the 1102. I searched the NI website but cannot find where to get them from NI. I read NI offers packs of four resistors. Is there a specific part number I should search for?
P.S. I thought we used a current sensor years ago with the same DAQ equipment but the transducer stopped working and we discontinued using it. Is it possible the SCXI-1102/1303 was set up from the factory to make current readings on channel 0? I don't see any resistor on the equipment. A photo of what I am looking for would be great! Can you tell I am a mechanical guy without much faith in his ability to do electrical work like soldering to the SCXI-1102? Thanks in advance for any help!
Solved! Go to Solution.
10-06-2011 05:21 AM
Does it have to be from NI? You can get resistors anywhere.
10-06-2011 04:36 PM
Hi Willard,
The SCXI-1102 is designed to acquire voltage signals of current signals from 0 - 20 mA; however, the 1303 terminal block is designed specifically for making thermocouple measurements. The SCXI-1102/1303 was not set up for current readings on any specific channel. However, perhaps you used a different terminal block designed specifically for current measurement such as the SCXI-1308?
Regarding the resistors you require,you can use the resistors found here:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/1644
10-06-2011 04:46 PM
10-06-2011 05:24 PM - edited 10-06-2011 05:25 PM
But hey, they are vintage through-hole style! 🙂
Sorry, could not resist.
Ohm my gosh that was bad.
Please show some tolerance to these bad puns.
-AK2DM
10-06-2011 10:07 PM
Gee, I never thought I'd find a place that sells resistors more expensive than Radio Shack.
The universe never ceases to amaze me.
10-07-2011 03:15 PM
Julianne thanks for the reply. I finally got around to opening up both SCXI-1102 modules and neither one has a resistor in any of the RCLx positions. We bought the first DAQ in September 2002 and the second one around 2005(?). Both use SCXI-1102/1303 combinations. Our first amp transducer was purchased around 2003. I believe its output was 0-5 mA. As I mentioned in my posting, it quit working years ago and we finally purchased a new one whose output is 0-5 mA. I know we used the old one for years and the LabVIEW software displayed the correct amperage values. However, I don’t know how we did it! Maybe I was fortunate in the way I configured that channel and used a conversion formula in LabVIEW to get approximate values for current. It is a mystery.
We will try the 249 ohm resistors. Thanks again for your help.
10-07-2011 03:24 PM
@Darin.K wrote:
Twenty bucks?!?!?!
Yeah, 20 cents for the parts, and $19.80 for the convenience.
10-13-2011 11:11 AM
@Darin.K wrote:
Twenty bucks?!?!?!
Est Shipping 10-15 DAYS!?!?!?
are they being carted by pack-mule?
10-13-2011 12:45 PM
wow... $5 per resistor...
