08-03-2014 09:58 AM - edited 08-03-2014 10:00 AM
@Scotty2541 wrote:
I came across board this while doing a search. It's the closest thing I could find (quickly) to ask a similar question.
Where can I download a driver for PCI-6503, Windows XP or Win 7, that isn't a 1.5GIG download?
I can't believe it will take 1+ gig to drive this board (which I am buying surplus).
I wish to interface with the board using C/C++. I also wish to use it as a learning tool for writing a my own driver based on the RLP model.
Isn't there a download for a driver that will handle this, which won't saturate my bandwidth for hours (or days)?
Even the "nimhddk_windowsWDM" download is reasonable size, but the INF doesn't have the 6503 card, or the PID listed in it (0x17d0), so I assume that the package doesn't work with the 6503 board.
In fact, everything I've searched doesn't have any reference to tutorials to intros to the PCI-6503 board from the driver point of view. (I have the user manual 374938b.pdf, and a handful of other docs)
Where would I find such a sample driver?
-Scott
You are going to have to download the 1.5G file.
If you are at work with the high speed servers, what is the problem?
At home on Comcast's slowest service, it takes me about an hour.
08-03-2014 11:12 AM - edited 08-03-2014 11:12 AM
It's not for work. It's a hobby project at this point.
I went ahead and pulled it down. Ran the EXE as an unzip...
Now I have 1000's of files, and 900 directories. I didn't want to run a 1.5 gig install on my personal hobby PC. I don't have Labview, MS Studiio, or any of the other stuff. That's a lot of forest, to find one little tree.
Oh well. Maybe someone else makes simple PIO product out there, with a easy to find driver.
08-03-2014 11:25 AM
08-03-2014 12:02 PM
Yes, I am not using Labview, and this is quite a lot more than I need.
As my original post said, this was the closest forum message board I could find regarding downloading a driver. The PCI 6503 card is just a PIO board, and since I was replying to an NI engineer, I figured saying so would be redundant.
It apeared to me, through all my searches, that the DAQ mx download was the only way to find something to drive this PIO board. Which was a factor that landed my in this forum. Although my question was looking for an alternative.
As a background, I will be doing a lot of driver level development in the future (for NI and other products), I purchased a PIO board (surplus), and am using this to learn to program it in C (the board, not the language, I already have decades of C). The logical progression I intend to make, is to access the card first using the driver via a user program. Then write my own custom driver so 'critical' tasks can be done in kernel mode, rather than user mode.
So, I could not find a good forum to post in. Landing in this was luck. I was just hoping to reply to a posting by "Seth B." and get his recomendation, since he is an NI engineer.
But any advice is appreciated.
-Scott
08-03-2014 12:36 PM
08-03-2014 12:43 PM
Hadn't gone that far yet.
The PCI 6503 page only directed me to that 1.5 Gig DAQ mx download. But I found a NIRLP driver example, built it, and am looking at what it takes to modify the INF/source code to make it install for this board.
08-03-2014 12:45 PM
08-03-2014 12:47 PM
Thanks.
Searching for "multifunction DAQ " isn't turning up any forum message boards like you mentioned. Most everything is ' in Labview' in the subject or content.
08-03-2014 12:59 PM
I have no idea what you are doing. From the main page, you should see most active hardware boards.
08-04-2014 10:56 AM - edited 08-04-2014 10:57 AM
NI products are very prevalent in industry.
But if you don't want to put in the effort then it is your call.
When you run the EXE, the files are placed in C:\National Instruments Downloads\NI-DAQmx\9.9.0
From there, you would double-click on setup.exe
You'll want to do a Custom install.
Then, be sure to select ANSI C Support under Application Development Support
If you have any thoughts on using .NET in the future, select those support files as well.
