08-20-2010 09:15 AM
I currently had a computer crash which resulted in a complete reformat of my Windows computer system. When the system was rebuilt, the IT professionals made a backup of the reformatted drive before reformatting. Since I had a computer rebuild I now have to reconfigure DAQmx task in MAX but was wondering if there was a file (such as a task or configuration file) from the old system backup that would allow me to import the DAQmx task information in without having to reconfigure the task. The hardware on the system is unchanged. Thanks, Jeff
08-20-2010 09:56 AM
From Max select File>import or Export. Export will create a *.nce file that contains the MAX information you select and Import prompts you to selet the *.nce file you want.
Its a pretty good idea to save your config information frequently so that you can restore to a known good configuration if something bad happens (like a rebuild of the PC)
08-20-2010 10:00 AM
So if I had not saved a configuration file, then there's no chance of retrieving my previous Task settings?
08-20-2010 10:30 AM
Pretty much Yes, You will need to inspect the documentation of the various software that uses the tasks (and I hope you at least did that). Or you can guess
