06-28-2017 01:35 PM
Hi.Sorry for my very basic question but i want to create a custom button.Where i can save it( which folder/ path) for use from VI control's pallette?
Thank you.
Solved! Go to Solution.
06-28-2017 02:36 PM
If you save controls and VIs in the user.lib folder they will show up in the User Libraries sub palettes.
http://zone.ni.com/reference/en-XX/help/371361N-01/lvhowto/adding_vis_and_controls/
Customizing a control involves right clicking it and going to Advanced >> Customize, and from there you can save the ctl (control) file. You can also use this control without having to drop it from the palette by opening the palette and going to Select a Control... or dragging it to the front panel from an explorer window, among a few other methods.
When it comes to fancy reuse you can use VIPM to create packages which also has a palette editing feature. Then users of your reuse install the package and it puts files where they need to go, and installs these custom palettes.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
06-28-2017 02:47 PM
Wow!
Reads like you could write the book on this subject... Wait! I think you just did.
Ben
06-28-2017 03:42 PM
Thanks for the complement. I've thought about many times presenting on VIPM features and how I use them at user groups, NI Week, or just a series of blog posts. Of course I need to finish my other series of blog posts first on the automotive CAN bus.
