What should I use for analysing E1 signal?
Could someone help me and advice me what HW should I have to build in LV a tool for E1 channel analysing? I need to build a simple tool to receive, send, pass though E1 (2Mbps) signal. My tool should have two E1 ports.
Many thanks in advance.
Message 1 of 8
(4,558 Views)
What I used was a card from GL Communications. LabVIEW drivers are available.
Message 2 of 8
(4,554 Views)
Hmm, I thought about something what can I connect to my laptop. Do you know something like that?
Message 3 of 8
(4,548 Views)
I take it you didn't even bother to check out the web site I provided? Here's a more specific link.
Message 4 of 8
(4,543 Views)
mimimi,
Another company, and probably more cost effictive then GL, you can try is DSPG
They make a system which can be used to analyse E1/T1 PCM streams, it can be remotely controlled from a laptop.
Disclaimer: I used to work for the company, however have not really had any dealings with them in several years. When I was there they had a custom designed DSP card used to simulate/analyse a telephone network (introduce echo/delay etc) on PCM trunks. I wrote a whole bunch of LabVIEW test suites for the, they could probably customise something that would suit your needs.
If you need a contact at the company I could probably dig out an email address.
Message 5 of 8
(4,533 Views)
I did, but I've seen two big PCI card. Sorry, and thanks again.
nrp, thanks for info
Message Edited by mimimi on 08-17-2008 10:04 PM
Message 6 of 8
(4,532 Views)
No, you did not look at the link if you missed the USB solution.
Message 7 of 8
(4,520 Views)
hi,
Can E1 signal (2.048MHz) be interfaced with some  labview fpga module?
Message 8 of 8
(2,993 Views)
