01-11-2005 09:36 AM
01-11-2005 10:50 AM
@JeffreyP wrote:
I've got two vi's and I'd like to copy code from one vi to the other one to avoid having to manually recreate it in the target vi. The VIs have identical filenames but they're used for different applications so there are slight differences.
I've been trying this and getting lots of LV questions about saving other vi's when I try to close the vi into which I pasted the code. Apparently,
If a subVI is among those items copied/pasted, I believe I need to rightClick/replace the (pasted) subVI with the correct one in the file structure. (SubVIs for both VIs have the same filename.) Doing this seemed to reduce the number of files that LV asked me to save.
Also, if I copy/paste global variables, how can I be sure they're now linked to the correct global vi?
Any general comments or precautions concerning this type of operation are also appreciated.
Jeff
01-11-2005 11:49 AM
