02-19-2015 01:13 PM
What is this symbol, and where do I find it on the pallette?
Solved! Go to Solution.
02-19-2015 01:18 PM
That is a local variable to a front panel control. The easiest way is to right-click on the control you want to create a local variable for and go to Create->Local Variable.
02-19-2015 01:20 PM
Thank you very much. I had figured out that it was a local variable, but I had to right click and select "Change to read" from the menu.
Much appreciated!
