10-29-2012 03:01 PM
Does anyone know what property name is associated with property index 104204298?
It is a valid property for an Error Ring; the value is boolean, and is writeable, but changing it doesn't appear to have any effect.
10-30-2012 05:41 PM
Where are you finding this property index? If you could post a screenshot showing where you are seeing this information, it may help clarify your request.
10-31-2012 07:55 AM
In order to update my list of property indices (see http://forums.ni.com/t5/LabVIEW/Property-Indices-for-quot-Get-Property-quot-method/m-p/1526234#M5683...), I searched for valid indices for the new Error Ring object class. Most of them were already known, but I have no info on 104204298.
11-01-2012 08:17 PM
Oh ok,thanks for clarifying! That's actually a pretty cool list. Did you write some code to programmatically run through all the indices?
11-02-2012 09:48 AM
As the list has evolved over the years, I've used a variety of utilities to flesh it out. These days, when I find a new object (e.g. the Error Ring), I just run some brute force code that tries all the indicies (it takes a few days running in the bkgnd). The more elegant approaches don't find everything; in fact for the Error Ring, using ordinary methods will find no properties at all.
11-06-2012 05:47 PM
I’ve been looking through some documentation and haven’t found any mention of property name associated with that index. Is this information critical for any sort of application?
11-21-2012 12:20 PM
I discovered that 104204298 is: "Visible Items:Subdiagram Visible" (which doesn't mean anything on an Error Ring).
However I've discovered several more property indices of unknown names that apply to Error Rings:
1594996736 Variant: Cluster
1594996739 Boolean
1594996740 Boolean
1594996741 Boolean
1594996742 String: (.html file name)
1594996745 Boolean
