What is error -20007 from "Interpolate 2D Scattered (1D).vi"?
What does -20007 mean? And in general, how do I convert error numbers to something meaningful if LabVIEW's "Explain Error" cannot explain the error?
I've attached a an example VI where use Linear interpolation and I pass (0, 0, 0), (1, 0, 😎 to "Interpolate 2D Scattered (1D).vi" for the two known points and (0.5, 0) for the point to be interpolated.
(2,544 Views)
Accepted by topic author bmihura
Explain Error works fine for me. You need to type in the number.
 The explanation points out that 3 or more samples are required. You only have two.
Lynn
(2,541 Views)
Well that was easy. I must have typed in the wrong number somehow.
(2,519 Views)
You should use the "type what I was thinking, not what my fingers punched algorithm."
Lynn
(2,511 Views)
