10-22-2016 11:53 PM
I try to store every value when the case is true, but I do not know how.
How can I store all those values?
10-23-2016 12:39 AM - edited 10-23-2016 12:42 AM
Store where? You could build the array in a shift register, so read up on that. Alternatively, you could use a conditional tunnel, if you have a newer LabVIEW version. (You haven't told us your version)
I would recommend to start out with a few tutorials first.
10-23-2016 12:45 AM
I use a 2015 version Labview
10-23-2016 07:12 AM
OK, now follow Altenbach's suggestions knowing that you can also use Conditional Indexing tunnels (you should learn about these in Tutorial 3 or 4).
10-23-2016 12:19 PM
As I said, you still have not said what you mean by "store". One possible interpretation would be to just append them to a file. That would store them quite permanently. 😄
Building data in a conditional tunnel of an outer while loop is dangerous, because if you would abort the VI, all accumulated data is lost forever. Do you want to see the accumulated data as it builds?
