04-22-2014 04:30 PM - edited 04-22-2014 04:30 PM
Well, we decided to use network streams. Here is a strange one. Can anyone explain this one to me? I have resorted to transposing the data external to the process that receives it so a transpose doesn't have to be done in the receiver, which is resulting in a broken run arrow.
Full disclosure, this project we are required to use LabVIEW 2011, haven't tested in newer versions.
04-22-2014 04:43 PM
Seems to work in 2013. I know that doesn't help any, but at least you know.
04-22-2014 04:48 PM
LV11 SP1
04-22-2014 05:23 PM
Darin, note the VI is different (subtle icon difference). I am using write multiple. I should have been more clear, and thought that while posting but forgot to mention it.
04-22-2014 05:43 PM
This is a bug that was fixed in LabVIEW 2012.
04-22-2014 06:27 PM
04-22-2014 07:07 PM
And once again, the Always Copy comes to the rescue when you need a work around.
04-23-2014 10:40 AM
HAHAAH I just noticed your tags Darin. Well played.
04-23-2014 11:01 AM
Be that as it may, the tags weren't placed there by me.
04-23-2014 11:25 AM
Ah, it does say "everyone else's" tags.
