Weird bug in "Event Structure"
As you can see in the attached VI, the "Event Data Node" can be moved all over the Event Structure.
I don't know what caused this phenomenon.
Amir.
(2,604 Views)
Hi Amir,
recreate the event structure.
Does the same problem appear or is it connected to that special event sturcture?
(2,588 Views)
It's only this one.
New Event Structures act normally.
(2,584 Views)
Hi Amir,
so your problem is solved by deleting the "weird" event structure and recreating a new one...
(2,581 Views)
That is correct. I don't have a problem.
I just wanted to demonstrate this, because maybe it is a general bug in the Event Structure that should be take care of.
Amir.
(2,573 Views)
Would only be a bug for me if there were steps available for me to recreate the issue...thanks for sharing it anyway!
19jmc
Windows 7. LabVIEW 2011.
(2,559 Views)
You can see another example here - http://lavag.org/topic/3037-detachable-event-data-nodes/
There's no explanation there, but I'm guessing it's a feature someone added but didn't finish and it's probably just a flag set on the structure by accident.
___________________
Try to take over the world!
(2,543 Views)
