08-13-2012 03:14 AM
As you can see in the attached VI, the "Event Data Node" can be moved all over the Event Structure.
I don't know what caused this phenomenon.
Amir.
08-13-2012 04:28 AM
08-13-2012 04:34 AM
It's only this one.
New Event Structures act normally.
08-13-2012 04:35 AM
08-13-2012 04:41 AM
That is correct. I don't have a problem.
I just wanted to demonstrate this, because maybe it is a general bug in the Event Structure that should be take care of.
Amir.
08-13-2012 05:26 AM
Would only be a bug for me if there were steps available for me to recreate the issue...thanks for sharing it anyway!
19jmc
08-13-2012 06:32 AM
You can see another example here - http://lavag.org/topic/3037-detachable-event-data-nodes/
There's no explanation there, but I'm guessing it's a feature someone added but didn't finish and it's probably just a flag set on the structure by accident.
