10-25-2013 09:32 AM
I have a little problem with import WSDL from CAB.
IF I give web adresse http://ip_printer/services.wsdl
Labview say WSDL validation failed..
But if I give adresse through the browser I found this file....
<definitions xmlns="http://schemas.xmlsoap.org/wsdl/" xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:tns="http://www.cab.de/WSSchema" name="cabPrinterWebService" targetNamespace="http://www.cab.de/WSSchema"> <documentation>This is a cab Printer Web Service.</documentation> <types> <xsd:schema elementFormDefault="qualified" targetNamespace="http://www.cab.de/WSSchema"> <xsd:element name="statusRequest" type="xsd:string"/> <xsd:element name="statusResponse" type="xsd:string"/> <xsd:element name="listOfFormatsRequest"> <xsd:complexType> <xsd:sequence/> </xsd:complexType> </xsd:element> <xsd:complexType name="format"> <xsd:sequence> <xsd:element name="name" type="xsd:string"/> <xsd:element name="description" type="xsd:string"/> </xsd:sequence> </xsd:complexType> <xsd:element name="listOfFormatsResponse"> <xsd:complexType> <xsd:sequence> <xsd:element name="format" minOccurs="0" maxOccurs="unbounded" type="tns:format"/> </xsd:sequence> </xsd:complexType> </xsd:element> <xsd:element name="listOfObjectsRequest"> <xsd:complexType> <xsd:sequence/> </xsd:complexType> </xsd:element> <xsd:complexType name="objectType"> <xsd:sequence> <xsd:element name="name" type="xsd:string"/> <xsd:element name="type" type="xsd:string"/> </xsd:sequence> </xsd:complexType> <xsd:element name="listOfObjectsResponse"> <xsd:complexType> <xsd:sequence> <xsd:element name="fObject" minOccurs="0" maxOccurs="unbounded" type="tns:objectType"/> </xsd:sequence> </xsd:complexType> </xsd:element> <xsd:element name="listOfJobsRequest"> <xsd:complexType> <xsd:sequence/> </xsd:complexType> </xsd:element> <xsd:complexType name="job"> <xsd:sequence> <xsd:element name="id" type="xsd:string"/> <xsd:element name="date" type="xsd:date"/> <xsd:element name="time" type="xsd:time"/> <xsd:element name="status" type="xsd:string"/> </xsd:sequence> </xsd:complexType> <xsd:element name="listOfJobsResponse"> <xsd:complexType> <xsd:sequence> <xsd:element name="job" minOccurs="0" maxOccurs="unbounded" type="tns:job"/> </xsd:sequence> </xsd:complexType> </xsd:element> <xsd:element name="loadFormatRequest" type="xsd:string"/> <xsd:complexType name="loadFormat"> <xsd:sequence> <xsd:element name="generic" type="xsd:string"/> <xsd:element name="result" type="xsd:boolean"/> </xsd:sequence> </xsd:complexType> <xsd:element name="loadFormatResponse" type="tns:loadFormat"/> <xsd:complexType name="objectTypePrint"> <xsd:sequence> <xsd:element name="name" type="xsd:string"/> <xsd:element name="value" type="xsd:string"/> </xsd:sequence> </xsd:complexType> <xsd:complexType name="printFormat"> <xsd:sequence> <xsd:element name="objects"> <xsd:complexType> <xsd:sequence> <xsd:element name="fObject" minOccurs="0" maxOccurs="unbounded" type="tns:objectTypePrint"/> </xsd:sequence> </xsd:complexType> </xsd:element> <xsd:element name="jobID" type="xsd:string"/> <xsd:element name="numbers" type="xsd:int"/> </xsd:sequence> </xsd:complexType> <xsd:element name="printFormatRequest" type="tns:printFormat"/> <xsd:element name="printFormatResponse" type="tns:loadFormat"/> <xsd:complexType name="faultType"> <xsd:sequence> <xsd:element name="faultCode" type="xsd:string"/> <xsd:element name="faultString" type="xsd:string"/> </xsd:sequence> </xsd:complexType> <xsd:element name="faultResponse" type="tns:faultType"/> </xsd:schema> </types> <message name="getPrinterStatusRequest"> <part name="parameters" element="tns:statusRequest"/> </message> <message name="getPrinterStatusResponse"> <part name="parameters" element="tns:statusResponse"/> </message> <message name="getListOfFormatsRequest"> <part name="parameters" element="tns:listOfFormatsRequest"/> </message> <message name="getListOfFormatsResponse"> <part name="parameters" element="tns:listOfFormatsResponse"/> </message> <message name="getListOfObjectsRequest"> <part name="parameters" element="tns:listOfObjectsRequest"/> </message> <message name="getListOfObjectsResponse"> <part name="parameters" element="tns:listOfObjectsResponse"/> </message> <message name="getListOfJobsRequest"> <part name="parameters" element="tns:listOfJobsRequest"/> </message> <message name="getListOfJobsResponse"> <part name="parameters" element="tns:listOfJobsResponse"/> </message> <message name="loadFormatRequest"> <part name="parameters" element="tns:loadFormatRequest"/> </message> <message name="loadFormatResponse"> <part name="parameters" element="tns:loadFormatResponse"/> </message> <message name="printFormatRequest"> <part name="parameters" element="tns:printFormatRequest"/> </message> <message name="printFormatResponse"> <part name="parameters" element="tns:printFormatResponse"/> </message> <message name="faultResponse"> <part name="Error" element="tns:faultResponse"/> </message> <portType name="cabPrinterSOAP"> <operation name="getPrinterStatus"> <documentation> Printer Status. Input Values: ESCs, ESCz, ESCi, ESCl, ESCa, ESCj, ESC?, Generic, Label Output Values: Generic: A generic Printer Status, Label: The loaded Label, Other: see Programming manual </documentation> <input message="tns:getPrinterStatusRequest"/> <output message="tns:getPrinterStatusResponse"/> <fault name="faultResponse" message="tns:faultResponse"/> </operation> <operation name="getlistOfFormats"> <documentation> List of Formats. Input Value: void Output Value: The Lables stored on the primary card slot </documentation> <input message="tns:getListOfFormatsRequest"/> <output message="tns:getListOfFormatsResponse"/> <fault name="faultResponse" message="tns:faultResponse"/> </operation> <operation name="getlistOfObjects"> <documentation> List of Objects from the loaded Format. Input Value: void Output Value: The Objects from the loaded Format </documentation> <input message="tns:getListOfObjectsRequest"/> <output message="tns:getListOfObjectsResponse"/> <fault name="faultResponse" message="tns:faultResponse"/> </operation> <operation name="getlistOfJobs"> <documentation> List of last printer Jobs. Input Value: void Output Value: The last Printer Jobs </documentation> <input message="tns:getListOfJobsRequest"/> <output message="tns:getListOfJobsResponse"/> <fault name="faultResponse" message="tns:faultResponse"/> </operation> <operation name="loadFormat"> <documentation> Load Format. Input Value: The name from the Format Output Value: A processing status </documentation> <input message="tns:loadFormatRequest"/> <output message="tns:loadFormatResponse"/> <fault name="faultResponse" message="tns:faultResponse"/> </operation> <operation name="printFormat"> <documentation> Print Format. Input Values: The objects (name and value) from the label The JobID from the label The number of labels Output Value: A processing status </documentation> <input message="tns:printFormatRequest"/> <output message="tns:printFormatResponse"/> <fault name="faultResponse" message="tns:faultResponse"/> </operation> </portType> <binding name="cabSOAPBinding" type="tns:cabPrinterSOAP"> <soap:binding transport="http://schemas.xmlsoap.org/soap/http" style="document"/> <operation name="getPrinterStatus"> <soap:operation soapAction="status" style="document"/> <input> <soap:body use="literal"/> </input> <output> <soap:body use="literal"/> </output> <fault name="faultResponse"> <soap:fault name="faultResponse" use="literal"/> </fault> </operation> <operation name="getlistOfFormats"> <soap:operation soapAction="formatlist" style="document"/> <input> <soap:body use="literal"/> </input> <output> <soap:body use="literal"/> </output> <fault name="faultResponse"> <soap:fault name="faultResponse" use="literal"/> </fault> </operation> <operation name="getlistOfObjects"> <soap:operation soapAction="objectlist" style="document"/> <input> <soap:body use="literal"/> </input> <output> <soap:body use="literal"/> </output> <fault name="faultResponse"> <soap:fault name="faultResponse" use="literal"/> </fault> </operation> <operation name="getlistOfJobs"> <soap:operation soapAction="joblist" style="document"/> <input> <soap:body use="literal"/> </input> <output> <soap:body use="literal"/> </output> <fault name="faultResponse"> <soap:fault name="faultResponse" use="literal"/> </fault> </operation> <operation name="loadFormat"> <soap:operation soapAction="loadformat" style="document"/> <input> <soap:body use="literal"/> </input> <output> <soap:body use="literal"/> </output> <fault name="faultResponse"> <soap:fault name="faultResponse" use="literal"/> </fault> </operation> <operation name="printFormat"> <soap:operation soapAction="printformat" style="document"/> <input> <soap:body use="literal"/> </input> <output> <soap:body use="literal"/> </output> <fault name="faultResponse"> <soap:fault name="faultResponse" use="literal"/> </fault> </operation> </binding> <service name="cabPrinterWebService"> <documentation>A simple getStatus Web Service</documentation> <port name="PrinterWebServiceSOAP" binding="tns:cabSOAPBinding"> <soap:address location="http://192.168.27.182/soap.cgi"/> </port> </service> </definitions>
why it does not work in labview?
Best Regards,
Emmanuel
10-28-2013 11:18 AM
Hello Emmanuel,
please tell me first your current LabVIEW Version.
Best Regards
Simon
10-30-2013 05:56 AM
Hello Simon,
My Labview is edition 2013 SP2, but it's the same proble whith 2012.
Best Regards
Emmanuel
10-30-2013 08:18 AM
10-31-2013 02:01 AM
I have the same problem since 2010 (see here) I tried your workaround but it
doesn't work for me, with soapUI it still works.
Greetings
Stefan
10-31-2013 02:33 AM
Hello Simon,
I have tested, but It's not ok.
For the main.vi is right?
Always the same error.
Best Regards
Emmanuel
11-06-2013 10:38 AM
Hello Emmanuel
Yes the path is right.
Here a link for the handling with WSDL and LabVIEW:
https://decibel.ni.com/content/docs/DOC-22722
Best Regards
Simon
11-08-2013 12:44 AM
I have use the solution from Stefan.
Thanks to both of you
Emmanuel
My llb for other people....
Ps. If you make an update don't forget to post it
11-08-2013 02:32 AM
Hi Emmanuel,
can you please save your LLBs in LabVIEW 2012. At the moment they are in LV2013
and i didn't install it so far..
Stefan
