07-18-2014 11:37 AM - edited 07-18-2014 11:40 AM
Hello Fellow LabVIEW Enthusiasts!
I am trying to host images on a Web Service through LabVIEW. My goal is to be able to change the images programmatically. I attached the project (zipped). When I try to "Publish" the service, it says that the "new picture" in HTTP_Picture is unsupported data type. I couldn't find any examples on this topic.
Also, I tried the NI Web Publishing Tool... this tool works great on Windows machines, however, I cannot load the images on my Android device, the plugin is unsupported. This is the reason I moved to the HTTP Web Services route. Any help would be greatly appreciated.
Thank you,
Nick
07-21-2014 08:50 PM - edited 07-21-2014 08:51 PM
Hello Nick,
It looks like you folled the procedure outlined under heading 15 of this document: http://www.ni.com/white-paper/7747/en/#toc15
Before I get to heavily involved in this I am curious if the images will all be available at build time or if you want to make new images available on the web that were not available at build time. I think I would take different aproaches in the two scenerios.
- John
07-21-2014 08:58 PM
Hi John,
Thank you for your reply. I did follow many of the tutorials including the steps in the link that you referenced.
All of the pictures are known at build time. I am wondering if it is possible to have the HTML file of the web publishing tool accept LabVIEW commands to change pictures. I am still looking into other options, like you said there are many approaches possible to take. If I could find one that I know would work for my application, I would be able to focus and learn how to achomplish the task.
07-22-2014 09:49 AM
Nick,
I think you will have to do some sort of scripting. Since you know all the images a build time I suggest you add them all as static images. You can then use ESP or JAVA to change which static images (web pages) are visible.
http://www.ni.com/white-paper/7738/en/
are your images going to change when the user clicks on something? or will they change when some event happens on the host?
- John
07-22-2014 09:53 AM
I want LabVIEW to change which image is displayed on the webpage.
07-22-2014 10:33 AM
So you want something server side to change the image visible. correct me if that is wrong.
What I imagine at this point is a a bunch of static pages that are all images. Your startup VI can determine which image is available at any time. Client side I think you will write some script that asks the page to update every minute or so.
As I understand it now there will be no user interactionw with the page. The user will be purely a consumer.
07-22-2014 10:36 AM
Correct. I need a Java script (from an Android App) to change the visible image, however, it would be nicer if it were dynamic. I could then overlay text on the images.
07-23-2014 06:34 PM
I beleive some HTTP request needs to be made of the server in order to update the image.
Are the images always shown in the same sequence?
07-24-2014 07:14 AM
Yes, the pictures should be updated in a certain order. I am thinking that I need to send HTTP requests from the server to the client, the client will then refresh the page. Does this make sense or is there a better option?
07-25-2014 05:59 PM
Could you try using a gif?
