WaveformChart bug? (LV2014 SP1)
Hi all,
Here's a VI in which I set plot properties on a chart and then plot values in it every 100ms.
When I run it I get a "not enough memory to complete this operation" message, after hitting "Ok" on the message I can see that this message was not blocking the execution of the VI.
My assumption is that LabVIEW doesn't really like the order in which I set the plot properties and instead a throwing an error out of the property node, it throws this "not enough memory" message.
Can anyone test this in a more recent version of LabVIEW please?
Epictetus
Antoine Chalons
Message 1 of 17
(3,921 Views)
I get no error with LabVIEW 2015 SP1.
GCentral
Message 2 of 17
(3,918 Views)
... and here it is in LabVIEW 2016.
Message 3 of 17
(3,897 Views)
Ok, thank you both for trying.
So this issue doesn't appear in LV 2015 and 2016, that's good news.
Anyone can reproduce it in LV 2014 ?
Epictetus
Antoine Chalons
Message 4 of 17
(3,886 Views)
Hi TiTou,
just run your VI with LV2014SP1 and encountered NO problems…
Message 5 of 17
(3,880 Views)
GerdW a écrit :
Hi TiTou,
Aha... are you running LV 2014.0f1 64b ?
Epictetus
Antoine Chalons
Message 6 of 17
(3,878 Views)
Hi TiTou,
I'm running LV2014SP1-32bit (or "Version 14.0.1" in LabVIEW "About" window) on Win7-64bit:
Message 7 of 17
(3,876 Views)
Can you please try one more thing :
- open the VI
- run it
- stop it by closing the FP
- then right clic on the chart > Data operation > Clear chart
- then save the VI
- run the VI again
Cheers
Epictetus
Antoine Chalons
Message 8 of 17
(3,870 Views)
On LV2016 Mac evaluation version, the first time I run the VI, there is no issue, I stop it and re-run it an then I get a hang 😮
Epictetus
Antoine Chalons
Message 9 of 17
(3,856 Views)
Hi TiTou,
- open the VI
- run it
- then save the VI
- run the VI again
I did as you asked for: the VI runs in the 2nd run the same "flawless" way as in the 1st run…
See this result of VI properties -> Memory usage after the 2nd run:
I also attach your VI after saving it (before 2nd run)…
Message 10 of 17
(3,831 Views)
