Waveform graph's plot legend in multiple rows or columns?
I have a waveform graph on my front panel which can show samples acquired from about 100 different channels. I have difficulties to display the plot legend as it seems I can expand it only vertically OR horizontally at the same time (so like a 1D array). Is there a way to expand it to both direction?
Out of the 100 channels users normally want to see about 8-10 key plots at the same time (depending on the test type), but from time to time, they may want to check signals not "officially" related to the given test, so I have to have use plot visibility checkbox option as well. (which means, I really have to have all the 100 channels sampled)
Thanks.
Message 1 of 8
(4,390 Views)
1984,
You cannot change the default waveform graph to display the plot legend as a 2-D array.  What you could do though is create your own boolean array and use the properties "Active Plot" and "Plot.Visible?" to change plot visibility programmatically.
Message 2 of 8
(4,320 Views)
Yes... but thats way too much of a hassle. I see this as an unnecessary restricition.
thanks for your reply.
Message 3 of 8
(4,310 Views)
If you can make a good case for your desired approach, post it on the Idea Exchange.
Lynn
Message 4 of 8
(4,307 Views)
Well first of all let me rephrase: its not a restricition its a missing feature.
Second: idea exchange is great for popular ideas. Mine is sort of a corner-case, I wont get upvotes comparable to more common problems, so I dont think it worth the hassle.
Lynn
Message 5 of 8
(4,304 Views)
attached is a way to show a subset of plots and display their names/colors as a 2D array.
you'll still need to:
  1] have unique plot names and colors
  2] adjust the position of the 2D array based on number of rows
  3] figure out a way to show point / line styles if that's important
Message 6 of 8
(4,300 Views)
@Jacobson-ni wrote:
1984,
I would offer two possibilities:
One use a tree controll to select channels or groups of channels to display vice the boolean array:
Two Use TDMS and modify the built in TDMS Viewer to handle the display interface for you
"Should be" isn't "Is" -Jay
Message 7 of 8
(4,292 Views)
1984,
I still think that this is something that you should post to the idea exchange.  Remember that just because a lot of people might not kudo your idea does not mean a developer will not see the suggestion.
I cannot speak to the reasons this is not a feature in LabVIEW but I think applications that would require the plot legend to be expanded vertically and horizontally might want to look towards most robust solutions such as the ones proposed by Jeff.
Message 8 of 8
(4,254 Views)
