07-04-2006 10:42 PM
07-05-2006 12:42 AM - edited 07-05-2006 12:42 AM
Hi James,
The specs for the PCI 6221 list its analog input range as +/-10V - with damage possible above 15V (25V while powered.) One question is how the 289V signal is being conditioned prior to connection to the 6221. If you have an Oscilloscope handy, verify that there's a wavform to capture. Verify that the wiring matches the DAQ channel & hardware-configuration (for instance, if configured for differential-input, are you supplying both +/- inputs ?.) Assuming your board is [still] working, this sounds like a simple acquisition! - have you tried using any of the waveform data-acquisition examples that come with LabVIEW?
If you get one of the DAQ examples working, but not your own code, try posting the code that's not working.
Good - luck, and I'm hoping your 6221 is OK!
Message Edited by tbd on 07-05-2006 12:49 AM
07-07-2006 03:39 AM
07-09-2006 12:44 AM
Hi James,
I'm not an expert on "ringing-waveforms" (neither do I know much about quantum mechanics,) but I can help you acquire an analog waveform using NI data-acquisition products. I might have a few basic questions like: what's the highest frequency-of-interest in the signal being measured? What's the voltage range of the signal (0-10V), and how will the signal be [ground] referenced? How is the data-acquisition being triggered? Though unlikely, the signal's source impedance could also be important.
Try to set the DAQmx sampling frequency at least 5-times higher than the waveform you want to reproduce (the higher the better). If you can't make one of the shipping DAQmx examples work, the two most likely causes are: no signal at connection to DAQ hardware (check with scope), or there's a hardware configuration problem. Try putting a constant 5V on the input channel, ground a different channel, then make sure you can "see" (capture) these two levels where they're supposed to be.
