Waveform accidentally scaled before PSD, how to undo?
Before passing the waveform to Power Spectral Density VI, it was divided by 1000. I am getting my PSD output in dB.
How could I undo the effect of the division? Is there any factor to scale by?
The PSD used is the standard Labview VI, with all default values (except with dB on).
(2,320 Views)
I don't understand, do you not have the original data anymore? What happened to it?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,295 Views)
No I don't....I only have the scaled version now...
(2,290 Views)
Someone else many come along that's a lot more familiar with the underlying math, but I'm pretty sure you're hosed.
The lesson that you need to learn here is: always, Always, ALWAYS save the raw data -- then after the analysis save the results in a different file. And backup everything.
Mike...
LabVIEW Champion
(2,264 Views)
