01-13-2017 08:34 AM
I have a Labview 'read IQ' function reading a digitiser that is sending data to a Labview 'wavefrom graph' in a while loop. I can see the continuous analogue waveform but it scrolls slowly across the 'waveform graph'. On a real oscilloscope I can just set the trigger level to hold the waveform still; how can I get the Labview 'waveform graph' to hold the continuous analogue waveform still as there is no trigger level function that I know off, or should I be using another type of Labview graph/method?
Labview 11
01-13-2017 09:13 AM
You can use a case structure and place the waveform graph inside.
This case structure can be controlled by a simple boolean control or you can compare if the value is greater than a setpoint,
01-24-2017 03:29 PM
With that case structure the waveform either freezes (or disappears) when the incoming waveform is below the threshold level. Above the threshold level then there would be a snapshot. What I wanted was a method that would behave more like a traditional scope, where the waveform appears continuous but holds on the peak of the incoming waveform rather than scrole of the screen.
