06-05-2016 11:10 AM
Here is what I have done.
I used Bob's "element" as a data source.
Removed the mean to reduce the size of the DC or zero-frequency component.
Converted the complex output of FFT.vi to magnitude and pahse and plot the phase.
The only thing I changed from the default settings on Waveform Graph 2 is the Y-axis mapping to logarithmic.
Lynn
06-05-2016 11:23 AM
Lynn, thank you. It looks much clearly for me, but you added FFT.vi, as you said to get freq range (-inf;+inf), but I dont get a two things: how to get on the x-axis the frequency, NOT a numbers likes 100, 10000 and so on, I need to have a frequency, how to do that? I think it supposed to be done something if dT or sampling. You calculated FFT form Magnitude and have got a spectra, it is the same to do for phase? Please look at my example, I need that it looks like the same situation (y-axis mag, x-axis frequency) on the example.
06-05-2016 12:38 PM
To change the axis labels just select the labels with the text tool and type what you want.
To change the marker values on the X-axis you can use the X Scale: Multiplier and X Scale: Offset properties.
Lynn
06-05-2016 12:48 PM
Lynn, I want to get a freq domain and plot it with amplitude domain and phase domain. It is possible? That is why I am trying to do and get a graph. Can you help with code and re-fixed it? I dont know how to get plot the freq on the x-asis, you have seen too, that according data on the x-asis it is just numbers or it is sample numbers, I need a freq. Thank you
06-06-2016 12:49 AM
How to see frequency on X-axis? Not numbers i.e 10.000 as are at my code
06-06-2016 11:01 AM
Exactly, how to extract frequency from FFT spectrum?
06-06-2016 11:10 AM - edited 06-06-2016 11:11 AM
A waveform consists of 3 main parts, T0 (time of the 0th element), dT, time between elements, and an array of Y which is the magnitude of each sample of the waveform.
When you pass that through the FFT, you get a cluster that is very similar in construction to the waveform. You get an F0 (frequency of the zeroth element which is almost always 0. a dF, the difference in frequencies of each element of the array. And the array which is consistes of the magnitude of each frequency.
So if you have a value of 100 in the 10th elemente of the array. That means you have an amplitude of 100 at a frequency of 10 * dF. If dF is 1 Hz, then the magnitude is 100 at 10 Hz.
Feeding that cluster into a waveform graph, because of its similar construction, allows you to see an FFT graph.
06-06-2016 11:29 AM
Thank you. RavensFan, I have a waveform with dT 5microseconds and I want to multiply this waveform with basic generator sinusoid, how to get the same dT to sinusoid? it is dT of waveform will be the same 5microsendos if I will dT to "basic generator sinusoioid" of plugin called"cycles"?
Thank you
06-06-2016 12:03 PM
There are several different functions that can create a sinewave. Just make sure whichever one you pick, you use the same dT when creating the sinewave.
I'd have to see a VI using whichever sine wave creator you are using to know if you have the inputs wired correctly.
06-06-2016 12:17 PM
Thanks, I want to use "basic function generator". I am trying to do 200000 samples with dT 0,000005. How to do it with "basic generator"? Should I do samples with cycles calculation, but where to connect?
Thank you
