Waveform Acquisition and Logging on CompactRIO template
Hi
I got the given template from NI and I am trying to adapt it to my NI 9223 module at a 9074crio. But I cannot configure the properties like 'Data Rate' and 'start/stop' the module. Is that anyway to create these properties for the specific moudule. I am not sure taking out these properties if the VI will work well.
Thanks for any answer
(2,972 Views)
Hi UserLab,
You're probably trying to directly use the template with your hardware configuration.
To better understand how to use it with your hardware, when you select the template, please click on the 'More Information' tab as shown attached and refer to the 'Adapting this Sample Project to Your Hardware'.
Let us know if you were able to proceed your configuration.
Best Regards,
Lirat Mulaj
(2,861 Views)
Hi UserLab,
I'm coming back to have an update if you were able to adapt your hardware configuration to your code.
Best Regards,
Lirat.
(2,770 Views)
