05-13-2013 09:54 AM
I went ahead and created CAR 407586 regarding the behavior where the display format types are not grayed out correctly after changing the data type through the properties window.
I did not create a CAR for the integer having digits of precision since there are valid use cases where a user might want the visual impression of decimal points but has integers on the back end (currency as an example). A change like that would have too much potential to affect existing user code, and the controls function correctly even if they do have extra meaningless digits.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
05-13-2013 10:13 AM
Jeff, there is already CAR 188530 for this.
05-13-2013 10:17 AM
Thanks for the heads up! I linked the CARs and closed the duplicate I just created.
I had done a search for similar CARs, but had not seen that one.
Jeff Peacock
