WSN using Labview
I am trying to build a WSN. The data needs to be sent to labview. I will be using Xbee gateway to recieve my data fron each node. Now I need to know if there is a way to send my data from the gateway to the labview wireless. Also Do I need MyRio to do so? is there a Xbee library in the labview that reads and parses the xbee data?
Would really appreciate all the help i can get. Thanks
(2,429 Views)
Hi nahid91,
What are the model numbers of the gateway and nodes you are working with?  Are you using one of NI's gateways?  This would be a NI-9791, NI-9792, or a NI-9795.
Also, for WSN questions I would recommend posted to the WSN board here: http://forums.ni.com/t5/Wireless-Sensor-Networks/bd-p/430
Kelly B.
(2,388 Views)
