03-24-2014 01:46 AM
HOW DO I CONVERT A PULSE WAVEFORM GENERATED FROM AN IR SENSOR USING MYDAQ TO DISPLAY A PQRST ECG WAVEFORM USING LABVIEW
ATTACHED BELOW IS THE PULSE WAVEFORM WE HAVE GENERATED AND WANT TO CHANGE.
03-24-2014 02:37 AM
04-01-2014 12:54 PM
Thanks for ur valuable advice sir,
but i did not post the question here for people having less knowledge in the field to ans.
if i had to fake it i would have,instead of asking here.
its advisable that u plz dont ans if u dont undrstnd the topic.
the doubt asked here is well valid and the conversion is possible,a ppg pulse waveform can be converted to a pqrs waveform with suitable algorithms nd processing techniques,only a little help is required but not suggestions to fake or change circuitry is entertained.
thanks,
regards subho
04-01-2014 01:33 PM
04-01-2014 04:04 PM
You might look into the Bio-Medical toolkit or ask in the BioBench forum. I'm with Gerd on this one though. If you think you're going to generate a meaningful ECG from the pulses in your photo I hope your patients have their final affairs in order.
Also, I suggest you avoid the use of that childish text-speak and take the time to write like an adult if you want to be taken seriously around here. It's especially ironic considering your snobby attitude.
