05-31-2010 10:54 AM
I'm attaching the file of the program that i want to do about the voice recognition. help me out please understanding what is the thing that i have to put in the global variable. Thanks.
P.S: It's in spanish!
06-01-2010 03:24 PM
06-01-2010 09:22 PM
Hi Alex, the global variables i'm talking about are in figure 9 which is called, "motor "and there is another one in figure 11 called "apagar". Do you know what does the subvi in figure 9 contains? Can yo explain me what is the function of a global variable and what kind of information it keeps? And also what does the matlab do and what is the info inside of it in figure 4. You can zoom it in order to see tha images better.
Thanks!! 😄
06-02-2010 09:42 PM
06-12-2011 06:12 AM
Hello!
This topic has been very helpful so far but there is something I still don't quite get it... Let's say that we focus on the "Get Temperature" example... There is a case structure called "speed"... what's the purpose of it? To control the desired frequency? I've tried to do somethnig simmilar with my project, but instead of that I want to control the slide(scrool)bar... The thing is I have a 0-120 bar so it would be stupid to define values separately... I understand this can be done with the "Decimal to string" function but i don't know what to set as an input. Thank you very mutch for your help!
B.S.
06-13-2011 04:35 PM
Hello Benjamin,
Where is the "Get Temperature" example you are referencing? I couldn't find it in this thread or on the NI Example Finder.
Thank you,
Deborah Y.
06-13-2011 05:33 PM
Oh I'm sorry for the misleading expression... I was refering to the Voice Recognition example in which the Get Temperature.vi is missing:
https://decibel.ni.com/content/docs/DOC-4477
My apologies,
B.S.
06-15-2011 02:25 PM
Hello B.S.,
I opened the example you're talking about and see the missing 'Get Temperature.vi'. Unfortunately, this was a customer-posted example, not an NI employee, so we're not going to know what that is until he posts it, which seems unlikely since it's a few years old.
In the 'speed' case structure, that Invoke Node sets the value of a named control or indicator of the variant, here it's 'Command'. You can wire a value of any data type to this method. For your application you would have the scroll bar you want to update be in the place of 'Command' in this example. You could similarly use the Decimal string to number VI and input the value you wish to set the slide to programmatically. Post if you have any questions.
Deborah Y.
04-10-2012 01:49 PM
Hello
I couldn't understand how the speed command should works , do i need to pronounce the world speed after that say a number or what ? , i ve tried many time but it doesn t work
thanks 🙂
04-13-2012 08:42 PM
hi
could you please help me to resolve this problem , my program is composed from those file : main.vi / robot.vi /Speech recognition test callback.vi / speech recognizer initialize
i explain the program at first , after running the main.vi when i say the word "robot" ,a program called "robot.vi" is going to be executed ,this part works fine , but the second part when i try to set a value to ''control value:set method '' i get nothing
best regard
Bahri Houssam
