Vision Assistant does not open image LabVIEW myRIO
Hi I just purchased a myRIO to deal with vision processing on our robot and I'm trying to use vision assistant but I'm having a few problems.
Using Imaqdx I can see an image from my Microsoft webcam and when I probe the wire in all different places before and after the vision assisstant it sees the image too.
However, when I open up the vision assistant to work on the script, it says there's no avaliable image to process.
I've used the vision assistant on several other projects and on a roboRIO in this way, so I'm not sure why this is not working. Attached is my current code if that's helpful.
Thank you for any help
(2,903 Views)
What's the point of the FOR loop?
(2,869 Views)
If you want to use the configuration window of the Vision Assistant, just grab an image and save it to file. Once you have one of a few sample images you can open them up in the Vision Assistant to work on your algorithm.
(2,844 Views)
