12-05-2014 11:39 AM
I'm very new to LabVIEW. I'm a senior, so I have had two measurement classes that used data logging equipment. I have had my hand held twice creating new programs. I just bought my first myRIO and I'm trying to datalog gps at 10 hz.
With the help of a few on here, I have been able to switch the Baud rate (I believe) but now I'm getting the Visa read error code 1073807253
I have attached my full program, but below are screen shots of things I have changed. The initial program worked fine at 1 hz, so I know the problem isn't the code itself, but it relates to what I'm changing. I did a bunch of searching and I found this page http://digital.ni.com/public.nsf/allkb/F3E0621CB71AA16786256F970000FC57 that talked about adding a buffer in the system.
I added the pause but that by itself didn't do anything. So, then I completed the modification and added the buffer.
That still resulted in the same error. After doing quite a bit of additional research, I found where someone said they just ignored the error. So, I gave that a shot and added an ignore error code.
Now the program runs without throwing up the error, but it isn't running correctly and it isn't running at 10hz. See the NMEA coded is it now displaying below.
Anyone have any ideas? I'm really stuck on this one and I'm behind schedule on completing this project. Any help is greatly appreciated!
12-05-2014 12:36 PM
12-05-2014 01:41 PM
I have done everything you advised (that I am aware of). I have posted up everything I have done. I have repeatedly asked for additional guidance and haven't gotten anywhere.
I figued this was a different issue seeing as I have a VISA problem now. So, i posted a new thread. I figured that once I came to a solution, I would post the solution on both threads.
What am I missing, what was the directive that I didn't do? I need help and don't really have a grasp on what or how everything works.
12-05-2014 02:46 PM
12-05-2014 02:47 PM - edited 12-05-2014 02:48 PM
here is where the disconnect is.
How do I do that. I thought that was what the NI Max was for. But you said to ignore that. So, I don't know how.
12-05-2014 03:02 PM
12-05-2014 03:10 PM
Ok, So, I got ride of the buffer and error ignore and went back to what I was using before.
I added in the close and put in a new Visa Config. I connected the error out of the Visa close to the Error in of the Config. Do I need to do that?
As you expected, the time between samples is still 1 second. Thoughts?
12-05-2014 03:29 PM
12-05-2014 04:47 PM
Here is the reference manual. The codes are on the bottom right of page 2
https://www.digilentinc.com/Data/Products/PMOD-GPS/PmodGPS_rm.pdf
Here is a video walk through of the code I'm using.
12-05-2014 04:57 PM
Here is another PDF.
