12-23-2014 07:25 AM
Hi.
I am working with Virtualbench. I want to program the IO's to four input and four outputs. I have tried to watch the example given by NI at:
http://www.ni.com/example/52071/en/
I have tested the example and from how I can see, it works as it defines all io's as output. If I apply any voltage to the inputs, the input Array Indicators does not change. If I remove the Virtualbench.dig.Write.vi in the program, the input array indicators is capable of seeing changes applied to the input channels. However, then all IO's are defined as inputs. I would like to have the inputs defined as above. Is this not possible?
\Morten
12-23-2014 09:43 AM
