Variable scope, how to set a variable from subvi??
Suppose we have a vi name  "example.vi" and this vi calls anothe vi name "SUBVI.vi". eaxmple.vi has an indicator name Boolean1. I want to set Boolen1 WHILE (this is very important) SUBVI is executing.
I attached the above vi's. Can you suggest a way to solve this problem?
(3,452 Views)
Accepted by topic author Hüseyin
Well you can update the reference to the boolean control in the mainVI from the subVI. Have a look at the following KB aricle:
How Can I Update the Changes Made to a Control/Indicator from a SubVI on the Main VI?
So, when the subVI starts execution, set the boolean to TRUE and when done, set it to FALSE.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,449 Views)
Thanks Adnan, that's what i want 🙂
Are you Turk? your name is used in Turkish.
(3,422 Views)
No, I am not Turk. 'Adnan' is an Arabic name and since Turkey is majority Muslim (I do know it's officially a secular state), I would assume most names over there would be similar to Arabic ones.
Adnan Zafar
(3,404 Views)
