Variable Engine crashes when querying a tag that doen't exist with OPC client
Hi!
I'm working on a system based on LV 2011 DSC.  The system is multi-node and uses Sahred Variables.
We have a node that has everything available in the system and we would like to use the embedded OPC server in the Variable Engine to grab everything in real-time and feed a corporate historian system.
It happened couple of time that querying a tag that was not defined in NI (example: typo when typing an address in the OPC client) caused some instability and made the node crash.  After a reboot, everything was ok.
Is there a way to prevent a supervisory system of making crash a production system?  Can we limit the OPC server to the defined tags in the library?
Thanks.
Francois
(2,397 Views)
The variable engine is known to be buggy from time to time, so be sure you upgrade all the related software to the latest version (or not 🙂
If it is possible, have the OPC client create a new tag for any that are queried, but do not exist.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(2,259 Views)
